What are using to read the CPU use?
could you post a screenshot of your processes?
press ctrl+alt+delete and go to the processes tab. then hit 'Prt Scr' usually located at the top right of the keyboard. open up microsoft paint and go to edit --> paste. save image as whatever you want, but make sure you save it as a jpeg(jpg). then when you go to post ehre, click the little yellow picture above the post box and insert the pic
ok, but do it again and make the window bigger so we can see all the processes, because that doesnt show which one is taking up the CPU
For one I can't see the CPU usage.. it's behind that white block that says 100%.. For two we know it runs at 100% you said it we don't need an image saying so. Go get hijackthis ( http://www.majorgeeks.com/download3155.html ) then show us an read out from there..
Idle is supposed to be that high... are you only looking at the Process taB? Take a look at Performance..
