.://HeLLCaT
Yes...I completely understand what's going on right now...
What's 64 bit?
What's 64 bit?
vista64 bit? why on earth would he need 64bit? just another headache to add to the driver hunt! he isnt even planning on use 4gb of ram
If your buying vista, why would you get 32bit? you can only use 3gb of ram compared to the 64bit 16gb, there are realy no driver issues with 64bit. If a company has drivers for vista more than likely they will have it for 32 and 64bit. 64 bit is more "future" proof, might not be too much longer and they will start having apps that require 64bit os's. It would be pointless to buy 32bit if your purchasing vista
What's 64 bit?
Judging by reviews and comments, Vista is pretty crappy right now and I should stick with XP...
If you build a computer, do you get a kit or just a bunch of seperate parts?
The most I'm willing to spend would 700 which is already a stretch for me, but why get something for cheaper that I'm not happy with when I can get something for a bit more that I prefer?
At this point actually, I don't know if I should build one or get this Alienware I've always wanted.
http://sfbay.craigslist.org/pen/sys/369642975.html
Is that a good deal?
