GeForce 7500LE
EGS
banned
I just bought a computer with, I think, a shitty video card :o :
GeForce 7500LE
256 MB DDR memory
I/O Ports: DVI, S-Video, VGA
Can anyone recommend me a nice replacement for this video card? :) One that would fit just as the GeForce 7500LE (so I don't have to replace any other hardware etc)?
Thanks in advance for your help! :D
is it an AGP or PCIe card. whichever it is just make sure you get onet hat is the same. it is probably a PCIe, in which case i recommend the 8800GTS. if that is a little too pricey, go with the 7800GTX or something around that
7900 gs id say. It takes less power than the 7800 gtx and has comparable if not better performance. I bought mine for about 130 CAD and it's awesome.
A++
The gt has more pixel pipelines yet the gs has a faster core clock and memory speeds, both are very close though. (looking at EVGA cards) Either seem good though.
I giggled when I read this, haha its quite the boost, if it can be done on his system. But with suggestions, I'd go with one of those 7900gs like said above. What kind of computer did you buy?
My computer, main specifications, are:
PROCESSOR
Core 2 Duo E6600 (C) DC 2.4 GHz
1066 MHz front side bus
MEMORY
Memory Installed 2 GB
Maximum allowed 4 GB* (4 x 1 GB)
*Actual available memory may be less
Speed supported PC2-4200 MB/sec
Type 240 pin, DDR2 SDRAM
HARD DRIVE
600 GB (2 x 300) SATA 3G (3.0 Gb/sec)
7200 rpm
I can handle almost every good video card...depending on my PSU.
I'd like to know from best price for best performance though.
