If you still don't have it working, check the manual. Cromewell is correct, but I have seen 1/2 3/4 on some motherboards...
Yes, that does happen every now and then but luckily it's an easy fix if your RAM isn't running dual channelhave seen 1/2 3/4 on some motherboards...
my mobo has four dimm slots, dimm 1 & 3 are blue, dimm 2 & 4 are black, i just put my ram in the matching colors (1 and 3) and now it says dual channel. i first installed them in 1 & 2 but single channel came up...
