Pentium D935 or D945
I will wait until Monday at least....so go with the E6600 cpu...suggestions on which memory and 2gb or 4gb?
2Gb with plans to upgrade to 4Gb maybe this Winter or next Spring. What OS do you plan on using? A 32-bit will only recognize 3.25Gb without some option setting, I recommend a Vista x64, if CAD will work.
As for name, I love Corsair, try this, the price will go back down to $110, I don't know what Newegg is up to:rolleyes: it was $110 when I looked at it a couple days ago.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
I was going to either go with XP x64 or Vista x64
Ran the Vista compatibility test and the only thing that said I needed to upgrade was my Nero software
I can figure that part out...just have to get something other than McAfee as it's a royal PITA to get through with their software running.
I'm assuming you're getting the OEM version of Vista x64? Last build I got the OEM version of XP pro and it was much cheaper
Oh...yeah OEM, definitely
