Trying to chip off as much $$ as i can from this rig.. help?
Noah
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119094 CASE - $54
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128034- mobo - $76
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145167 memory - $84
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103773 processor $ 170
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130038 vid card $286
http://www.newegg.com/Product/Product.aspx?Item=N82E16822144701 $65
http://www.newegg.com/Product/Product.asp?Item=N82E16817182017 PSU $55
I'm trying to make a computer that is setup like this to be around the $700 range, not sure if it's even possible, but i was wondering if some things i have were unnecessary and i could get a different product for a little bit cheaper. Thanks for any help that anyone gives, i appreciate it.
I usually don't really like to overclock, it's always just scared me a little bit. That little thought of something happening in the back of my mind was always too much. If you can chip off a significant amount of money by me OCing though, go right ahead, i'm open for any input. I'm mostly going to be using it for gaming.
awesome, thanks guys. Last thing i want to do is end up screwed with a shitty piece of hardware. How about a budget case?
You're just asking for trouble with that Rosewill PSU
If Tigerdirect were working tonight, I would show you an Ultra PSU
The one i linked was the "Ultra / X-Finity / 500-Watt / ATX / 120mm Fan / SATA-Ready / SLI-Ready / Black / Power Supply" for $40.... is that right?
