INTELCRAZY You should get A-Data. It is supposed to be a lot better than the corsair dominator series.
Don't worry! If ZipZoomFly runs out you can find it at newegg for the same price and rebate offer at http://www.newegg.com/Product/Product.asp?Item=N82E16820145168
Don't you like the xms series better?!
Will it OC to that? I heard that the Micron D9 was replaced with ProMos and it cannot overclock for crap....
Thanks
it can is just that those guys who wrote the reviews pushed the ram TOO far.
Thanks
the NON - dominator series are promos, those are all micron d9. it is overrated anyways unless you can actually overclock it to the said speed of others the cheap ones can overclock just as well.
