Well, where are they?
Thanks...my page didn't seem to find that one...can you suggest a cooler for it (I will be getting a GIGABYTE GA-P35-DS3R mobo)
depends on your case and how big between mobo and side panel.
1. thermalright ultra extreme
2.tuniq tower 120
3. zalman 9700
there are more but those are the one i would get it they fit :D
I have a mid tower case...was looking at the Zalman 9500 because it comes without the led on it (not into the flashing lights)
the non led version is not as good in cooling as the 9500 or 9700 i remember it was on 9th best cooler while the 9500 was 7th? and the 9700 led was 2nd or 3rd.
The price went up $10 in five minutes!!!! I can't order until after work, I am more than likely getting that, I might buy from Buy.com for $302.:)
It went up to $220...I just bought it for $198 at Zipzoomfly.
Those are 3 pin coolers...will they work with a 4 pin mobo...or do they make an adapter?
