cameronp29
wheres the best and cheapest place to buy a good monitor at least 21"??
thanks
thanks
hey neva sweet monitor. i might like this one better if you could answer this one question. A guy said it switches between his xbox 360 with the push of a button. What does he mean by this?? Does his xbox hook straight up to the monitor or does he mean he has his xbox somehow hooked through his computer? If you can hook it up straight do you use the same plugs??
Ive really been searching around and i might have found something. Could I get an Xbox 360 VGA cable and hook my xbox to the vga splitter and also have my computer hooked to the splitter. Then this would allow me to change between my computer and my xbox on the monitor with the press of a button??
Right??
If this is wrong please let me know. I want to order this asap. Also let me know if this is right.
becasue this is what i was thinking:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817107511
And just hook my xbox and monitor to this. They make a cable for xbox that i already have that hooks straight to this.
ok thanks neva fro all your help. I should be ordering that monitor and splitter by monday. I found an xbox 360 forum and im waiting on a response from someone whose tried it before. I want to make sure theres no skipping or anything during gameplay.
thanks
