Jet VIP Member Jul 28, 2007 #2 Most likely it won't be a problem, or there is a very small chance that it will be one.
Risingtide93 New Member Jul 31, 2007 #3 Jet said: Most likely it won't be a problem, or there is a very small chance that it will be one. Click to expand... Thank you. You relieved me by lot
StrangleHold Moderator Staff member Jul 31, 2007 #5 The only problem I can see you would have is with the way the harddrive stack is mounted to clear the bottom card.
