Need some logical answers
Dollar
I am sure many of you have heard of full HD lcd tv sets which runs at a resolution of 1920x1080. Now we have the latest 8800gts G Card from Nvidia which is capable of running a resolution of up to 2560x1600! Imagine that isn't better than the resolution of a full hd tv set if you use a monitor which is capable of displaying up to 2560x1600?
If you have links to these LCD monitors, please post them.
Also, yes, Running a monitor in that Resolution is like Super HD. But i'm not absolutely sure on where the point is where you'll stop noticing.. E.g anything above ____ x ____ and you won't be able to tell the difference.
thats so wrong, you can tell ez. just looks sharper
I was wrong on it being super HD? But come on.. it sounds so cool..
lol, I just used ma brain an inferenced. I never saw such a resolution so i aint really experienced or nothin. :o
On a bigger monitor it would stand out more, am I right?
mostly 27-30 inch monitors have that resolution.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824176071
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001098
Some examples.
So can I say the 2 above mentioned links are no ordinary LCD monitors as they are capable of displaying an even higher resolution than standard full hd tv?
