maroon1
No, 6000+ doesn't beat E6550 even a stock speeds
http://www.anandtech.com/printarticle.aspx?i=3038
And E6550 produce much less heat, and consume much less power than 6000+
E6550 consume 65W max
6000+ consume 125W max
So, there is no reason to get a power-hungry CPU like 6000+ even if you don't plan to overclock
Edit: And for the motherboard I recommend this
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131189
And get LG DVD burner, LG is usually better than samsung and it is cheaper
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136117
