INTELCRAZY
banned
Will I notice a difference in Crysis or Vista when I upgrade to 4Gb on the rig in the sig?
Thanks
Thanks
jump into a time machine and tell us. MAYBE you'll notice a difference if you run every single one of your programs at startup2gb is enough unless you feel better having all the slots filled in.
most i would get is 3gb.. maybe for my next rig.
Running all that RAM and having it all free can cause problems. I don't know the science of why it happens but I believe it can happen on VIsta as well, so long as you aren't using it.
