should i remove it?
Yeah, if you're using AS which is twenty times better than the stock crap![]()
alright man thanks. Just wondering is this the correct way of applying it?
http://youtube.com/watch?v=xTmgSCxdZ48
Ok i got a centurion 5 case but then theres no way to remove the I/O Shield plate wtf.. How am i suppose to install my mobo then
Ok and how would i place a new one back in?
BTW do i have to remove those things on the I/O shield? Those spikes thingy
