Ram
Depends what you consider "value" and "decent". But if your running Vista, then either way I would say get the 2GB.
What a company calls "value" ram is never usually bad ram. I have a pair of Geil Value sticks and I've never-ever had a problem with them.
Watch out for value brands though, they can be yucky.
2GB is generally the "sweet-spot" nowadays for pretty much any system. It's definitely worth it as you will probably upgrade to Vista at some point too.
