Message Board
g4m3rof1337
I need a precoded easy to customize message board.
I have a GoDaddy domain, thats hosted on a Linux server, and supports coding like PHP and stuff.
I need this site up, and I am not big on coding atm.
Thanks.
I would like it to look like CF.
And user accounts if possible.
simplemachines Is a forum that I have installed for clients in the past, and I was well pleased with it. It is based on PHP/Mysql, free and should install with a minimum of fuss.
PHPBB 3 is cool.
For a club/clan or other, I recommend getting PHP Nuke which is free ( I think so).
PHPBB 3 is cool.
I have not found that PHPNuke is too secure; hackers seem to find it easy.
I would avoid PHPnuke at all costs. If you want a Content Management System with a built-in forum, I would look at geeklog
Thanks.
Well, if you want the same look and feel of CF, then you'd want to go with vBulletin, which I believe is a bit pricey. There is also Invision Pro Boards which are a bit cheaper.
