jimmymac
Ok so having a few teething problems with a recently completed upgrade....
Basically just installed AMD X2 6000+, Asus Crosshair Mobo, 2GB DDR2 800, ATI radeon X1950xt.
Fun and games were had with installing XP home afterwards but that seems to have been solved. Formatted the hard drive prior to that so it was from a clean slate...
Now i'm having a little issue of the system hanging every 5-10 mins. Everything stops responding for about 10 seconds and then its all fine and off again.
Temps are fine, previously checked and showed the CPU at around 32 degrees celsius....
Any ideas what might be causing it as its a little annoying!
