spanky New Member Aug 6, 2007 #2 You should post your system specs to make a decsision like that and what you use your pc for. Edit: Also Welcome to ComputerForum.
R Red Dragon New Member Aug 6, 2007 #4 games, video, other things I'm just thinking if i get a computer should i go with vista I heard that some things won't work on vista
spanky New Member Aug 6, 2007 #5 Red Dragon said: games, video, other things I'm just thinking if i get a computer should i go with vista I heard that some things won't work on vista Click to expand... Supposedly MS will be releasing a SP for Vista late this year. But if you're getting a decent PC, probably vista.
R Red Dragon New Member Aug 6, 2007 #7 i have xp on the one I'm on now can i use the things on it on vista I heard that some things won't work on vista is that right?
Michael Active Member Aug 6, 2007 #8 You can use not-so-compatible-programs by setting the compatibility to 'XP SP2' in Vista, which helps in most cases i've come across.
