Suggestions needed
1950pro is equal to the 7900gs
7950gt is better than either
7950gt is equal (well, close) to the 1950xt
1950xtx is better than both, but it's also runs hotter as well.
Aha, I think you have missed out the 7900gtx. So how would you rate it?
I disagree with you
X1950Pro is better than 7900GS
X1950XT is better than 7950GT
79xx might run cooler and overclock better, but they are not better at stock speeds
However, I strongly recommend 8800GTS 320MB because it is better than any of those video cards
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150171
I think the 7 series beats the X1K series when you factor in all the variables. The 79xx runs cooler and generates less heat at stock speeds and its price is around the same as the X19xx. The 79xx clearly beats all its ATi counterparts overall. I would strongly recommend a DX10 card, its just not worth it forking out for an obsolete DX9 one.
I disagree with you
Oh come on.
What's the difference between the cards I was mistaken on? A couple FPS? I'm not going to consult benchmarks everytime I have to compare a lineup of cards unless they're are card I'm unfamiliar with.
Close enough. :P
