skidude
Got a ton of those bulky, wide IDE cables laying around? Well recently I had an idea to try and make these cables into round ones to make my case look better, and it worked out great! Here is a step-by-step way to make your own, complete with pictures!
Step 1
First, take a regular IDE ribbon cable and place it on a flat, hard surface. Be sure there is plenty of light in the room. Also needed is a roll of electrical tape and either a razor blade or a very sharp knife.
Step 2
Take the knife and gently cut in between the wires in the cable, spacing cuts about 4 or 5 wires apart. Be sure not to cut into the wire itself, just cut the material in between the individual wires.
Step 3
Peel each cut down the entire length of the ribbon cable.
Step 4
Bunch up all the strands together, and wrap it tightly with the electrical tape, be sure to get it 3-4 layers thick.
Then simply plug it in any enjoy all that empty space!
Step 1
Step 2
Step 3
Step 4
