DS3L Vs. DS3R?
martyvice
I've been looking at these two motherboards:
Gigabyte GA-P35-DS3L w/ DualDDR2 1066, 7.1 Audio, Gigabit Lan, PCI-E x16
Gigabyte GA-P35-DS3R w/ DualDDR2 1066, 7.1 Audio, Gigabit Lan, PCI-E x16
To me they seem identicle but are obviously not, can someone tell me the difference between the two?
I don't plan to overclock, and I'm going to be using a E6550, with 2 GB PC6400 RAM and most likely a Nvidia card.
I'm leaning towards the DS3L since the price is tempting, but am wondering if it's $100 for a reason. Will I be fine with that mobo?
Thanks.
The DS3L has half of the sata port the DS3R does, it doesn't not have raid and is practically a cheap version, if you don't need over 4 sata ports then go for the DS3L
i would go for the second one:
1)optimized power savings, ultra cooling and extended system durability
2)supporti for both Blu-ray and HD DVD formats
I guess it's always worth it to spend a little more on the motherboard.
Best way to futureproof your computer.
