LCD Monitors
g4m3rof1337
Can I see some computer monitors that are good for gaming, and can have an Xbox 360 hooked up to it.
Anything under $300 is great.
Preferably over 20'' and wide screen.
Thanks.
If you want to use you're Xbox 360 on the LCD, then you want one with component input or you can buy a VGA cable for the 360, which is what I did. With that cable you can connect it to any VGA port, whether it be an LCD monitor, projector, or TV.
http://dealmac.com/deals/Acer-AL205...onitor-w-DVI-for-300-after-rebate/119697.html
"Click buy this deal" on the right, in the green box , to buy it.
just looked at the monitor... it sucks. why would anyone pay $300 for that piece of crap? seriously. only 800:1 contrast ratio, and a very high 8ms response time. (not that bad, but compared to some lcds, like mine, thats pretty bad)
22" acer widescreen $199.99 after rebate
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2430647&CatId=2775
8ms isn't high, 16ms is high and 800:1 is definitely acceptable.
The LCD you linked to has a 700:1 c/r with 5ms response.. not much different than the one you're bashing, bud.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009094&Tpk=Acer+AL2216WBD $225 without a rebate.. if you go through TD and expect to get that rebate back, good luck :P
$50 rebate on 22" Acer LCD, good monitor from what I've heard
EDIT: Whoops, already been posted, sorry. The 20" is pretty good for the reso, and DEFINITELY good for a 360, get real, why is he gonna need 1000:1 ratio for a 360?
