Justin_Garrett
How do I disable Internet explorer from starting automatically? I use firefox 99% of the time so I don't need Ie to be running. I have crap cleaner, but I can't disable it there. Any help would be much appreciated!
			do you mean that you are trying to end in the processes tab explorer.exe if you are that is the windows explorer thing and its part of windows thats why your computer freezes up
