help
notsmart101
well first off i know my computer sucks and is slow....but besides that i cant delete old game files....i click uninstall it says no game data....i hit play it says the same thing....i go into my programs and try to delete it from add or remove programs and same thing????
sounds like you deleted the programs out of the c:/program files without uninstalling them or removing them from add/remove programs... if you reinstall them and then uninstall them properly it might work
^ that cleans your registry only.
Delete the whole folder, then try to remove. Add remove programs should say that it was already deleted..
i cant reinstall the game cheburns sorry forgot to say that
ill try that zengetsu
and sorry.... but i have no idea how to do that lol
Hey oscaryu1,
He tried deleting everything, so he had to use that program to clean his register and to erase the software that was still on his computer.
wow zengetsu's idea worked....thanks man.....and bleach is a good show nice name
I am very glad that it helped. And yes, Bleach is indeed a great show.
Zangetsu
