hows this build
First off I would go with an PCI-E 16 card because that basically the standard now... and probably at least a 79-- or something like an 8600.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143070
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130084
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130086
That PSU is way more than you need... try something like
http://www.clubit.com/product_detail.cfm?itemno=A6200026
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
If you want to stick with that processor thats fine I'd look at this mobo see what you think its good for the price
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
there are a couple ideas for where to go... if you gave a budget you had to fit in I'd be more specific
Whats your budget? What OS do you already have? And what case? Are you using the computer for gaming or for other things?
I'd put a build together for you but I have no power so I'm on my phone :/
mostly music, internet and some gaming...like the new command and conquer tiberium wars 3 is what ive been playin but this one im on (in my room) cant play it....and i forgot about the HDD...lol just like a western digital 200 gig would do i think....and i ment to put up a 7900gs i put the 7600 up by accident....and i have windows xp home...not a fan of vista yet....my bidget is $500-$600 around there is good...thanks for the replies
Quick build :
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115015&Tpk=E6320
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127015
MOBO
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211174
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136062
HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127286
GFX
Total : $504.41
Notice that the RAM is DDR2 800 rather than DDR2 667 :D DDR2 800 was cheaper :D And cas was lower than rest
Might wanna check that hte mobo will fit in your case... if not, P180 or something...
i like that build oscaryu1 you think itll be any good....like pretty fast....and yea ill prolly go with the E4500 if it really is better and cheaper
Don't get any less than a 600watt PSU 500watt is the norm these days you want to be able to run the 1GB graphics cards in the near future. The latest ATi cards requires 600watt for the overclocking of it.
Buy a sound card the Creative ones process lots more sounds at a time and in 3D so the sound bounces off walls and around corners it makes all the diference and turns your comp into audiofile music playback.
I have an 600W with 24A on the rail...
course that can run an 1GB GFX... definitely
