cellfactor problem
ducis
I tried to do the whole "EnablePhysX=false" thing with cell factor but I still get the same privileges as I did without it am I doing something wrong?
Heres are some screenies
I've tried to "enable physx" on the options menu but when I restart it goes back to being disabled and when I don't restart it goes back to being disabled
Does any one know what I'm doing wrong?
Please don't bump after just one hour.
For starters, Check that you have Complete Administrative rights on that Application.
Vista has a habit of dis-allowing programs full administrative rights thus stopping any major changes.
Does your Graphics card support Physx?
Are you talking about Cellfactor: Combat Training? Because that only works with PhysX cards.
I'm not too sure, I know the first one didn't need it, but you could use a PhysicX card if you wanted, I've got a demo for the second one, I'll try play it now see if it works, I don't think you should need it though, it would of said or not worked at all, what does it do?
I beat level 2 easily, and then I go to the level select menu and no level 3? So WTF!?
I really don't know what the problem is sorry, I haven't tried the GRAW 2 demo yet, so I can't tell you if it needs a PhysicX card, but I really doubt that it does! Try starting again and see what it does, back up your current save games though.
