J_D
Hi
My uncle was looking to buy a computer to fit in his lounge under the TV, however it was very difficult to find any that met his requirements. So we are now looking at building one our selves.
This will be a first build so, gunna need help from you experienced guys/girls out there.
Ok the main spec requirements we are after is:
Ok just so you know here is a PC that fits some of the requirements
http://www.laptopsdirect.co.uk/Acer_Aspire_L100_Ultra_Small_Desktop_97.KUB7Z.UFM/version.asp
However it comes with a "free" 19inch monitor that we don’t need so the price of that is buried inside it, and also the graphical power of the system is weak. It’s an integrated chip, when really it would be nice to have a PCI-E slot.
Anyway here are some components I found: (Please comment on compatibility and stuff)
We will be nicking a DVD Burner IDE from another computer that is not needed anymore.
I can sort out the graphics later, (got an oldish one that would do) but can someone tell me if a PCI-E graphics card will fit in that case (i.e. is it deep enough. AND also what about the Fan for the CPU? Will that have airflow in this case?
Any help will be much welcome. Thank in Advance.
J_D
- Small Form Factor Case (Not a shuttle, more like an oversized DVD Player case)
- A mid-range graphics card (going to be used by my cousins for gaming)
- min of 1 GB RAM
- would be nice to have a Duel Core CPU but will be looking at the low end
- small budget (£300-£450) or USD ($570-$855)
- Case: uATX with 250WPSU Link
- MoBo: uATX MSI Link
- CPU: AMD AM2 Athlon 64 3800+ Link
- RAM: 2GB (2x1GB) CorsairTwinX XMS2, DDR2 PC2-6400 Link
- HDD: 200 GB Western Digital WD2000JS Caviar SE, SATA Link
J_D
