GREAT way to clean out your computer
tool72
alright. open up your pc, take it outside, get a leaf blower, and pretty much blow all the dust out of it. it works...trust me
TOOL
Canned air is a bit more precise, and doesn't get exhaust and gas fumes in your comp :D
I was going to suggest an air compressor! :P But yeah, that's what I use. Though you do need to be careful with them too. Moisture can build up in the tanks...
I used to use compressed air but i ran out so now i use a paintbrush thoroughly then hoover up all the dust thats fallen out to the bottom.
Who Would Use A Leaf Blower?
Well . . . Thats one way to get Fumes In on Your PC
Compressor FTW!
Our Compressor is drained after Every Use, So We dont worry about the Water Catchment, It also has Moisture catchment on the way out too.
Its Good :D
ya i need to get a new air compressor. i got a 80$ one from costco. it is so bad. it is like one gallen and i have a 11 gal tank that is portible. i sware i smell burning rubber when it is done filling it. time for a better one :D
My old Compaq Presario 5,000 had an overheating issue so I took the side panel off for more airflow. So of course it accumulated dust real quickly. I just took it down to my dad's air compressor and blew it in short bursts (not to get moisture on anything). Clean as a whistle...
