7600gst
It's probably the best under the gt.. And it'll be sufficient if you're an average gamer.
Out here in the states it would cost around $70-80 so it sounds a tad overpriced, but you definitely could of done worse.
yes it is, here in the philippines vidoe cards are overpriced....and products are limited so this is probably the best card i can pull out...in terms of speed the 7600gt runs at 560core clock/1400mem clock right? the gst runs at 500/1400 is the difference noticeable when you game?
It's also missing a couple pipelines too, which is more important. I'd say the GS is Around 70% that of the GT.. That estimate varying depending on game.
It's a pretty good card. You can play a game like Oblivion med-high at a 1280 x 1024 resolution.
Officially, yes. But in reality you could probably get by with a 250-300w PSU with at least 16-17 amperes on the +12v line.
You sure it's missing pipelines? I thought they were exactly identical except core/memory speed.
