microatx build comments pls?
I got that free shipping email from newegg.. isn't it only for the specified items within the email?
i like the e6550 and the xclio idea but what is better about the gigabyte mobo other than that it has ddr2 800 instead of 677...
The Gigabyte natively supports the 1333MHz FSB CPUs such as the E6550, the board you listed won't even run the CPU you also listed at stock because the 945 chipset family have a maximum native FSB of only 800Mhz. Plus it's the new Intel G33T chipset. I would have gone for P35 (more overclockable) but there appear to be no board with this chipset in mATX format.
oh crap i didnt even see that
ty
IMO, MB, change to GIGABYTE GA-G31MX-S2 or GIGABYTE GA-G33M-S2
Not suggest using Asus MB, as lots of people comment Asus MB is hot.
And I agree as PabloTek to get a E6550 for extra $10
RAM can using any of those Cheap DDR2 800 2x1GB
GPU, can also consider HIS Hightech H260XTF256DDN-R Radeon HD 2600XT 256MB or SAPPHIRE 100208L Radeon HD 2600XT 256MB Because ATI support HDCP
PSU: suggest to getting one with Modular Cabling Support like CORSAIR CMPSU-450VX as you use such a small case, although it is a little expensive
