First of all, Hello to everyone. I just registered here.
I'm having problems booting up my PC. It will not start up if i leave it for a while after shutdown. When the power button is pressed the lights will tun on for just a split second and go off. Press again nothing will happen. But if press and hold the power button for about 5 seconds and release and then press again the lights will blink once just as before and nothing will happen.
When this happens, what i do is turn off the power from the mains and leave it for a while and turn it back on. It will then start up with no problems at all. Restarting in windows has no problems either. And so does shutting down and pressing power button before it gets too long, like 5 minutes.
Another thing i noticed is that in a normal start up the processor fan starts turning after a second or two along with a single beep. At times when it won't start up, the processor fans starts instantly when power button is pressed and stops.
My PC specs;
Intel(R) Core(TM)2 Duo CPU E6850 @ 3.00GHz
Gigabyte GA-P35-DS3 rev1.0 (Bios rev. F4)
Corsair CM2X1024-6400 (pair of total 2GB)
MSI RX2600XT 256M DDR4 PCI-E graphics card
Seagate Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive
LG HL-DT-ST DVD-ROM GDR8163B (DVD-ROM Drive)
LITE-ON LTR-24102B (CD-RW Recorder)
Agere systems PCI softmodem
SiS 900 PCI fast ethernet adapter
USB mouse and keyboard
HP Deskjet 3940
OS: Windows XP Professional
Power supply: As the label on it says, PowerLogic magnum 250
Max/peak = 450W
Pure/real = 230W
+3.3V = 15A
+5V = 22A
+12V = 12A
-12V = 0.5A
5Vsb = 2A
P/G = OK
Thanks for any help on this issue.
My PC specs;
HP Deskjet 3940
Max/peak = 450W
Pure/real = 230W
+3.3V = 15A
+5V = 22A
+12V = 12A
-12V = 0.5A
5Vsb = 2A
P/G = OK
