well i am thinking of getting a mac (although it conterdicts every belief i know) just so i can help more people here and later in life. but my question is will the os run on just a normal pc or do i have to get a mac?
i hate it... hate to say. i never tried it i am just against the mac " cant change anything" although it does have a reliable os. i will just get a mac mini and just use it to fool around. need to save up a few pay checks and come up w/ a excuse of why i need to get it for my parents/ brother... they will ask for 100 years why i will get it.
I don't use macs very often, but for some reason, I find it really fun. Its almost like playing a game or something.
First off OS X x86 is illegal and breaks apple's EULA, plus from what I have read it runs like crap compared to OS X on an actual Mac.
also gaming will soon no longer be a barrier between OS X versus windows. OS X Leopard will offer a set of APIs for developers to use called Core Animation, which is Apple's version of Direct X. Also, there is a translator called Cider, which allows game developers to easily translate their games from windows to OS X. From what my Apple SE told me, Cider only translates a few things and most of the game is kept in its original code, which means porting will be easy.
If you want a mac go buy a mac. A new Mac comes with the OS, and with installer DVDs of the OS and all the bundled apps.
OS X Leopard will offer a set of APIs for developers to use called Core Animation, which is Apple's version of Direct X. .
Animated sequences execute in a thread independent from the main run loop, allowing application processing to occur while the animation is in progress. In this way, application performance is not affected, and animations can be stopped, reversed, or retargeted while in progress
The translator does not modify any original code, it just allows OS X to translate the code from windows into something that OS X can read natively. Google search Cider and you can read all about it. It is a transgaming technology.
Apple will never let their OS be installed on other systems in the near future. You see, an Apple computer is completely built from the ground up. They design every aspect from hardware to software and OS. Therefore they have way greater quality control over their product. That is what makes them so reliable. I don't think they want to have all the third party SNAFUs that MS has with their OS.
Perhaps in the distant future when they gain a certain market share will they allow other companies to load their OS. With Apple you are always getting high quality machines.
mrpidly-
Core animation is a set of APIs built into the OS, game developers can use this. It is not exactly like DX, but is similiar since DX is also a set of APIs. Core animation allows developers direct access to many Open GL technologies with in OS X. I can see game developers using it, but they may not.
I am not talking about companies... I am talking about ppl like me.. Build it and screw Dell, HP, Alienware, etc.
You are missing the point of the Macintosh platform. It is a closed platform which is how they have such a high quality control and why they are reliable. Would you try to put ford parts in your Porsche?
I wouldn'tThat's why I will never game on a Mac until they release their OS... I think they should release the older versions for use on built PC's to End-Users... Like when Leopard comes out, they can sell Tiger on a disc? That might work...
Well that would be physically impossible for any previous version of OS X since they are all built on running on PPC hardware. Tiger at OS X 10.4.6 was the first OS installed on the intel platform macs. You wouldn't need to build a mac to get a high end gaming machine, just have to buy a mac pro, which I know is a lot of money.
Really what apple should do is build a C2D mid range tower with an open PCI-E slot that a gamer could slap in any video card they wanted, then voila there you go.
Oh and the entry level macbook pro has a C2D 2.2Ghz processor, 2 gigs of ram, and a 8600m GT video card in it, which will run any game you want to. No need to spend 3000 on a laptop just for gaming. Plus gaming on a laptop kind of sucks.
