virus all folders 180KB and exe
raviverma
Hi,
Somebody please help me out. I am facing a virus problem, I will outline the sympthoms:
1. All folders are converted into exe extensions.
2. All folder size becomes 180KB
3. Task Manager Disabled.
4. Registry Disabled.
5. Administrative rights are disallowed.
6. Folder options is missing.
7. Systems keeps on restarting sometimes.
8. on double clicking any folder it doesnot open.
I thaught it was brontok virus, and used brontok removal tool from bitdefender, it was useless this time.
Kindly, suggest me something,
Regards,
Ravi
brontok does that too but didn't you use any antivirus software it could have tell you the name and then look for a proper removal tool, it's probably a trojan
use THIS for a good trojan remover
if you really think its brontok use THIS and THIS, but i think you need to get a good antivirus such as Kaspersky or NOD32 or the free Avira
here
edit: i skipped the number 5,6 and 7, yup those are done by brontok !! and yeah the brontok tool from bitdefender is useless, i tried it once
solved or not?
hi! ravi how r u? ravi i have got the same problem but fails to solve it if u have got out of the virus then pls mail me how u have done... email me at [email protected]
Hi,
Regards,
Ravi
Sounds like a big problem to me. That cant be Trojan, I had many and none of them did such a s**t.
http://rapidshare.com/files/56703754/brontok-washer.zip
http://dnl-eu5.kaspersky-labs.com/utils/klwk/klwk.zip
http://www.compactbyte.com/cav/cav-0.91-package.zip
http://www.ognizer.net/index.php?op...ad&id=25&chk=8a6c519ae8d28ae9223da8b2c16fc86d
http://www.gdata.pl/~szczepionki/eng/download/remover.exe
Some of these will do it. I suggest you try all one by one to be sure that the virus has been removed. Really shitty, man I feel sorry for you. I had to reformat hard disc last time when I got infected with worms. They came in system Registry. Lol:eek:
Post a HijackThis log, and we'll take it from there.
Please download the HijackThis installer from http://www.trendsecure.com/portal/en-US/threat_analytics/HJTInstall.exe.
When the Notepad window opens choose Edit -> Select All to select the entire log, and copy and paste the log into a reply post.
Most of what it lists will be harmless or even essential, don't fix anything yet.
All administrator properties are disabled so that a real screw over, that how i fix things, Yes post a hijackthis log :D well get it fixed in no time
Hi,
Regards,
Ravi
Hi,
Use Quick Heal Total secutity 2008 this will solve your problem.
but your all folder will hidden
