My PC
Aianiel
Hey Everyone,
I have a plan to build myself a PC and just thought it would be a good idea to list the components here. This will be my first time ever building a PC so any suggestions would be appreciated. But, most importantly if any of the components don't work with each other. Heres my list (with links):
Rosewill R6AS5-BK 0.8mm SECC 120mm Fan ATX Mid Tower Computer Case - Retail (h
ttp://www.newegg.com/product/product.asp?item=N82E16811147040
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard - Retail
(http://www.newegg.com/product/product.asp?item=N82E16813128059)
XFX PVT84JUDF3 GeForce 8600GT 256MB 128-bit GDDR3 PCI Express x16 SLI Supported Video Card - Retail
http://www.newegg.com/product/product.asp?item=N82E16814150230)
Intel Core 2 Duo E4400 Allendale 2.0GHz LGA 775 Processor Model BX80557E4400 - Retail
(http://www.newegg.com/product/product.asp?item=N82E16819115014
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ - Retail
(http://www.newegg.com/product/product.asp?item=N82E16820231098
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
(http://www.newegg.com/product/product.asp?item=N82E16822136073)
Saitek PZ30AU Black USB Wired Standard Eclipse Keyboard - Retail
(http://www.newegg.com/product/product.asp?item=N82E16823175103)
Acer AL1916WAbd Black 19" 5ms DVI Widescreen LCD Monitor - Retail
(http://www.newegg.com/Product/Product.aspx?Item=N82E16824009091)
Microsoft 9VV-00001 Black 7 Buttons 1 x Wheel USB Wired Laser Habu Gaming Mouse - Retail
(http://www.newegg.com/product/product.asp?item=N82E16826105016)
LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-06 - Retail
(http://www.newegg.com/product/product.asp?item=N82E16827106072)
Turtle Beach TBS-3300-01 7.1 Channels 24-bit 96KHz PCI Interface Montego DDL Sound Card - Retail
(http://www.newegg.com/product/product.asp?item=N82E16829118109)
Microsoft
Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD - OEM
(http://www.newegg.com/product/product.asp?item=N82E16832116204)
Logitech X-230 32 watts RMS 2.1 Black Speaker System - OEM
http://www.newegg.com/product/product.asp?item=N82E16836121123
Please tell me if I am forgetting anything! This will be the first PC I have ever built. Also, do I need a special kind of fan and heatsink for my cpu?
Thanks!
Hey Everyone,
Microsoft
Thanks!
I would go higher than the 8600GT, and get a Creative sound card. Great choice of motherboard. And you don't need an aftermarket heatsink, I would suggest it though.
Get one of these cases, Rosewill is cheap...
http://www.newegg.com/Product/Produ...000007&Description=Apollo&name=Computer+Cases
What kind of power supply? I would suggest this
http://www.buy.com/prod/corsair-520w-sli-certified-modular-atx-power-supply/q/loc/101/203270716.html
You missed a power supply other than that is k, but i agree get a creative card instead, a G5 instead of that microshit mouse and you don't need the saitek neither is that good as to spend 40$ on it, if you can get the E6550 instead of the E4400
Damn, I did forget to paste a link for the power supply. I was thinking of getting a 600-650w supply. Is that powerful enough?
and yeah, i'll get the G5 haha
And do I have to get a heatsink that matches my processor? (Such as one that matches the lga 775 format)
Look at my signature, I run an 8800GTX off of one... These Corsair(relabled Seasonic PSU's) run true to wattage unlike most others.
