help make a PC is better than 360/PS3 thread here
which gives better graphics
  • PC
    Votes: 23 85.2%
  • 360
    Votes: 4 14.8%
  • Total voters
    27
has Intel, have you SEEN the 360 play F.E.A.R.? if you have, what res do you think that it? Kobaj, if you actually truly look at it and compare you can easily tell. if you did not know, super hi res take an enormous amount of processing power. such that the 360 can not handle.
Resolution isn't everything.... What about coding for movement? I think it's still open to debate... I know the PC beats it but, you get my point. I think that it plays at an average DVD's resolution
If you say a 360 you don't know anything about computers or xbox 360's.
actually i know alot and just becausei said "a 360" its slang for xbox 360 geez... and mine post was an opinion and i did say that it depends on the carD. IM NOT A FANBOY of either off them i like them both but im not obsessed quit assuming things...
PC, i know a few people with ps3's. Graphics look good but 90% of the games lag... maybe not bad but they aren't smooth.
actually i know alot and just becausei said "a 360" its slang for xbox 360 dumbass... and mine post was an opinion and i did say that it depends on the carD. IM NOT A FANBOY of either off them i like them both but im not obsessed quit assuming things...
He wasn't referring to your post...
He meant that for the whole thread, this is what he implied, "If anyone in the thread says an Xbox 360 is better than a PC, then you don't know much of anything". That was his opinion that PC is better.
I think dollar for dollar you get the best graphics with the 360 but obviously higher end computers will stomp 360 and I am not impressed with a few games on the 360 they seem to get a noticeable drop in frame rate when played in high def. Like sure MS thanks for giving us high def with 360 but it is annoying how some games become unplayable in high def...Even the original Xbox had HD capabilities with the component adapter but only a SMALL handful of games supported 1080i.
build a rig with a core 2 extreme 6850 and two 8800 gtx in SLI mode with some high dollar ram, run crysis on ultra and put it side by side with any 360 game. question answered.
