I JUst Build My FIrst Pc. Pc Probe Problem
Johnny_Cage
First Pc System specs
Asus P5w
160gb WD
2gb Gskills
Core2 6600 Artic Cooling Fan
XFX 8500
Raidmax Smilodon Case w/ 500 watt PSU
How Would You Rate My Pc? Im not good about knowing voltage. But I have a problem i use pc probe and it says +12v and +5V out of threshold.
Its like this 9.302+12v and 5.51+5V? And then it show Cpu Fan,Power Fan, and Chassis Fan are below Threshold? What is going On? Would Appreciate the help. I dont want to damage anything it cost me much money.
Asus P5w
160gb WD
2gb Gskills
XFX 8500
That GFX card is not that great... One program goes bad, just don't panic... Vista?
Yes Sir Vista Basic.
ooh...Yeah, PCWizard2007, Speedfan, and SuperPI all had problems on my Vista Home Premium with incorrect read outs. Some ppl with less hardware were getting 22s in 1M of SuperPI, I was getting 2m 3s, which is horrible for my hardware. It's a compatibility bug. Speedfan says my board temp is 254*C, I know it would melt at that:rolleyes: PCWizard gives me like 1,700,854RPM on my CPU fan, that's impossible.
XP too. Speedfan ready my 2600+ at 16C, motherboard monitor readys my CPU at 364C...
Yeh i tried pc wizard it say +5V 5.41 and +12V 14.34 so and help? Does it cause a problem with the Voltage?
Even though the software might read it wrong. Just to make sure.Do I need A new psu or something? If So what u recommend? I dont really no about psu its hard to understand.
