HELP ME! delete annoying message!!
starlight
I recently installed virgin media broadband onto my pc when getting connected again, but seemed to have a problem (its sorted now!) so my bright idea at the time, knowing not a lot about computers! was to install my old NTL install disk i also had a problem so i cancelled the set up and now every time after starting my pc I’m getting a message/pop up? saying Broadband installer Reboot Helper. I just want to get rid of it!
I’ve been looking in task manager and found that its called Recover from Reg.... i can only seem to end it temporarily. Please help me make it permanent
Thanks to anyone who'll help.
i've already tried doing that more than once its still there! is there anyway you know of where this can be deleted
i don't know anything about registry cleaner!
Download CCleaner. If your problem is a registry issue, you can fix your registry with this application. Before you run a registry fix, CCleaner will ask you if you want to backup your registry - you should. You never know, things might get hosed up. :eek:
