System requirments????
brian
ok as you can tell i dont have spell checker at my work computer :D. so bare with me. ok so i have 3 laptops. one dell one hp and one gateway. all have eather this i or system requirments button. you hit it nothing happens. what is this and what should it do?
sorry. ok on a keyboard. a normal one it is on the print screen key. on laptops it is fn some key over near end. but it has sys rq. if you hit it nothing happens. what is the key for
on a laptop, u hav to use tht key to use print screen(FN + PRT SC)... atleast, its the only way it works for me...
A quick Google found this
The alternate use of this key is for the "system request" function. This is a historical command originally based on older IBM terminal designs, and is not really used any more.
