Respital
Hey guys i am thinking of building a new computer i just need you to tell me if al the part are like good and that everything is supported by everything k thanks
Case: Ultra eTorque Black Mid-Tower ATX Case with Front USB, FireWire and Clear Side
Which can be found here : http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2337814&sku=ULT33180
Mobo: Intel 975XBX2KR Motherboard - Intel, Socket 775, ATX, Viiv Ready, Audio, PCI Express, Gigabit LAN, S/PDIF, USB 2.0 & Firewire, Serial ATA, RAID
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2563503&sku=I69-2145
CPU: Intel Core 2 Quad Q6600 Processor - 2.40GHz, 8MB Cache, 1066MHz FSB, Kentsfield, Quad-Core, Retail, Socket 775, BX80562Q6600, Processor with Fan
Which can be found here:
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2905631&sku=CP1-DUO-Q6600
Ram: OCZ Platinum Revision-2 2048MB PC6400 DDR2 800MHz Dual Channel Memory (2 x 1024MB)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2882686&sku=O261-8070
Video Card: EVGA GeForce 8800 GTX / 768MB GDDR3 / SLI Ready / PCI Express / Dual DVI / HDTV / Video Card
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2597917&sku=E145-8000
Power Supply: Ultra / X-Finity / 600-Watt / ATX / Dual 80mm Fan / SATA-Ready / SLI Ready / Titanium / Power Supply
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2974508&sku=ULT31847 K
Hard Drive:Western Digital / Caviar SE16 / 500GB / 7200 / 16MB / SATA-300 / OEM / Hard Drive
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2795126&sku=TSD-500AAKS
DVD Burner:LG SuperMulti GSA-H62N SATA DVD Writer - 18x DVD±R Burn, 16x DVD±R Read, 8x DVD+RW, 6x DVD-RW, 10x DVD±R DL, 48x32x CD-R/RW, Black
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3187849&sku=L49-GSH62N CA
Thanks For Reading
Thanks For Reading
