OEM vs Retail
Which Version...
  • OEM
    Votes: 13 92.9%
  • Retail
    Votes: 1 7.1%
  • Total voters
    14
Geoff
Nope, OEM is the same thing as retail minus the box and packaging. You have the same license agreement with both versions, you may be thinking of retail vs corporate?
I believe you can activate with the same CD Key twice, the first time you install it and then a second time, but you may have to call up Microsoft.
HumanMage
I would imagine you could upgrade everything you wanted to because you do have a "genuine" copy of the OS but if you go OEM you might not get all the "books" or something that come with a retail OS, plus you save alot of money.
Jabes
banned
yea all you have to do is call microsoft you can activate it as many times as you want from my experience and oem doesn't come with any support from ms but retail does I'm pretty sure but y do u need support
Kornowski
Ok, so I could possibly upgrade the motherboard and stuff, I'd just need to call MS and tell them...
If you uprage the CPU, do you need to install a clean version of the OS again?
Yeah, it's a hell of a lot cheaper, and you don't need the support, like Jabes said!
Jabes
banned
usually its safe to just so that u don't have any problems
edit: vista ultimate retail come with a 32bit and a 64 bit disk?
Kornowski
Yeah, All the retail ones come with 32bit and 64bit DVD's, problem is they cost like twice as much! I'd get one otherwise!
Kornowski
Yeah, it's stupid isn't it!
If I get the OEM version, can I call MS and get them to send me a 64bit DVD for a small amount of money?
Kornowski
I heard there was a thing, where you talk to MS if you have a 32bit version of Vista and they can send you a 64bit version of it, for like £7 or something..
Geoff
I've never heard of that, but why would you get 32 bit in the first place?
And to answer your previous question, replacing the CPU wont require you to re-activate. However if you change motherboards then most likely you will need to re-install (and re-activate), Windows, but possibly not if it's the same chipset.
Kornowski
Oh right, maybe it was somebody talking BS then :p
32 bit, because it's more compatable...
I'm seriously confused now, I don't know, 32bit or 64bit, If I can get a wireless reciever to work, then I'd get 64bit! oh, and all my games work! :p
I just need to know the answer to this question, then I'm done :( :confused:
http://www.ebuyer.com/customer/prod...hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=109708
This Linksys one, is apparently supported.
It uses the RT2500 chipset, so, If I'm right, On this page:
http://www.ralinktech.com/ralink/Home/Support/Windows.html
I'd download the second set of the drivers, the
USB(RT257x/RT2671
ones?
Do you guys think this will work?
If not them I'm really considering getting 32bit...
Geoff
If a company has drivers out for Vista, most likely they will have one for both versions. If your going to spend the money on Vista, at least get one thats a bit more future proof.
