first build need help on deciding on a motherboard
trod
I think I have my build planned out. This will be for general computer use and the rare game might be played. I just dont know anything about motherboards and I need your help. I will be overclocking the e2160 . Please help me decide. I will be purchasing everything from directcanada so it has to be something they offer. I have listed all the components and some motherboards I saw there that looked good. I eventually will upgrade to a quad so I want the motherboard to be compatible with that. I also realize that the OCZ platinum RAm and the PSU are overkill but with the rebates they are the same price as lower components. Is this PSU good? Are these components compatible?
Thanks
Intel DP35DP ATX LGA775 P35 DDR2 1333FSB PCI-E16 3PCI-E1 3PCI Gbe Viiv SATA2 Sound Motherboard $121.47 http://www.directcanada.com/products/?sku=12200BD3697
Gigabyte GA-P35-DS3L Atx LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound Gblan Motherboard $94.36 $94.36
http://www.directcanada.com/products/?sku=11830BD1399
ASUS P5B-MX mATX 946GZ LGA775 Conroe DDR2 1PCI-E16 1PCI-E1 2PCI SATA2 Video Sound GBLAN Motherboard $80.89 $80.89
http://www.directcanada.com/products/?sku=10530BD1729
ASUS P5B SE ATX LGA775 P965 DDR2 PCI-E16 2PCI-E1 3PCI SATA2 eSATA Motherboard$100.44 $100.44
http://www.directcanada.com/products/?sku=10530BD2181
ASUS P5K SE ATX LGA775 P35 DDR2 PCI-E16 2PCI 3PCI-E1 SATA2 Sound GBLAN Motherboard$120.96 $120.96
http://www.directcanada.com/products/?sku=10530BD9334
Intel Pentium Dual Core E2160 Dual Core Processor LGA775 1.8GHZ 800FSB 1MB Retail
$86.99 $86.99
http://www.directcanada.com/products/?sku=12200BD3219
Coolermaster CAC-T05 Centurion 5 Aluminum ATX Tower Case 5X5.25 1X3.5 4X3.5INT SILVER-BLACK No PS $52.38 $52.38
Ocz Platinum Xtc REV.2 PC2-6400 2GB 2X1GB DDR2-800 CL4-4-4-15 240PIN Dimm Dual Channel Memory Kit
* $40.00 CAD Mail in Rebate for this item - click here
http://www.directcanada.com/products/?sku=13220BD3804
Yes $120.74 $120.74
Ocz Stealthxstream 600W ATX12V 20/24PIN Active Pfc Atx Power Supply 120MM Fan Black
* $10.00 CAD Mail in Rebate for this item - click here
http://www.directcanada.com/products/?sku=13220AC0022
Yes $78.65 $78.65
Seagate Barracuda 7200.10 500GB SATA2 3GB/S 7200RPM 16MB Cache NCQ Hard Drive
$113.99 $113.99
http://www.directcanada.com/products/?sku=14120DR1310
Diamond Viper Radeon HD 2600XT 800MHZ 256MB 800MHZ GDDR3 Dual DVI-I HDCP VIVO HDTV Out Video Card
$115.44 $115.44
http://www.directcanada.com/products/?sku=11340BD5036
