it worked wit the elmers glue so eat that
I suggest removing immidiately. Get some Arctic Silver Thermal Adheive... if you don't want to destroy that card...
Yes it will work until you get to the "gaming" part... then the errors will come more than ever.
First of all, why would you use children's glue? If you actually wanted to use glue for some idiotic reason, super glue would be a more obvious choice.it worked wit the elmers glue so eat that
