who is running a p5n32-sli premium?
p5n32
If anyone is running it can you plss send me your ram spes and PSU and cpu specs plss and does anyone know if a 8400gs is supported by p5n32-sli thank you guys :):confused:
Although I have never used this Asus mobo, I can tell you the 8400gs is compatible. Why wouldn't it be?
I'm running the P5N32E-SLI board and I'm using Corsair XMS PC6400 DDR2 800mhz memory with mine and have no problems. Every Asus board I've ever owned I used Corsair memory and never had a problem.I would at least get a 8600gts card though, simply because the 8400 is very low end.
I'd go for a lesser board and get a decent GPU, I know the P5N32 is a good board (we run one here) but there are other boards that are just as good for a bit less.
