creating boot disk in win vista
If you have the Vista installation disk simply boot up with that and go into the repair tools section on the first screen when that loads. Unlike seen with the XP installer the new version now sees the ability to format an NTFS partition before or without installing Windows afterwards. MS included a separate formatting tool there as well as the better partitioning tool.
You can also use gparted. Just burn the iso and reboot and re-parition.
You first have to know which one to use as well as a live for cd release not one run from a VFat 24bit Linux partition. The screen shot below shows how to distinguish the two only "platform independent" releases apart for the Linux only types.
The above is seen at http://sourceforge.net/project/showfiles.php?group_id=115843&package_id=173828
For the full documentation as well as screen shots for learning how to use GParted review the information seen at http://gparted.sourceforge.net/larry/generalities/gparted.htm
pc eye, i booted up the win vista cd and went into in the repair mode and selected command prompt, i then entered "format c:" is that a good way of formatting the c drive or is there a better command line you can enter
When you boot from the installation disk there's no need for the command prompt since the option to format is now available. You then select the drive and partition. This is an automatic tool now seen with the new version where you simply point and click without manually typing in any commands. You can even resize existing partitions with the new drive tools as well as MS including the Linux memory testing utility memtest.
