Hello,
If anyone had any input on this, I’d really appreciate it. I received a Dell Dimension 8100 1.3 GHz computer that had a bad hard drive in it. It came with what I believe is its original XP SP2 installation disk. So, I pulled a hard drive out of another computer that I have (this hard drive is known to be good because I was just using it and it was working fine). I then used that original installation disk to try and boot up to my this known-to-be-good hard drive.
Here’s what is happening. It actually is booting up OK. At one point in the installation it prompted me for instructions as to how to format this hard drive. I deleted all partitions and told it to do a FAT32. Which apparently it did. I’m seeing progress that is normal on the monitor. The bar is advancing. I’m getting messages that change every minute or so telling about the features of XP. But, . . . it is taking several days for this process to complete itself. Right now it is at the point where it is “finalizing installation.” The DVD player (where the installation disk is at) turns on and off occasionally. This whole thing shouldn’t take days, it should take maybe hours. Does anyone have any idea why it is taking so long? Like I said, even though it is taking so long, it appears to be working otherwise correctly.
Thanks.
Thanks.
