What Type Of Expansion Slot Is This?
Hi there.
I was just wondering if any of you knew which type of expansion slot my mobo contains. (See Images)
I know it has 1 AGP slot which i presume is the brown one, but then it just says it has 3 PCI slots.
I was wondering if anybody knew wheather the slots are either PCI or PCI-E.
Thanks In Advance
Those white ones are PCI. If they were PCI-e, whatever you're reading would say that instead of PCI.
The Blue and Black are PCIe X16 slots, the White ones are PCI slots.
As a general rule of thumb if you have a agp slot you most likely don't have a pci-e and vise versa. Also gp with a agp card because the agp interfae is much faster thus so are the cards and you will end up getting more bang for your buck (or pound) with an agp then pci.
