hello
I am looking to upgrade my HP M8000N
I want to boost the ram to 4gb currently only 2gb
I believe the ram that is in my system is pc2 4200. I think it will support 6400 (pleas confirm) would i notice the boost if i have 2 slots with 4200 and two slots with 6400 would i be better off replacing the 4200 and having every thing 6400. or cost wise would i just be better off buying 2gb of 4200 and calling it good.
newegg has 8 pc2-4200 2x1gb kits listed $59-75 the top 4 listed are corsair, Kingston, g skills and crucial. i am leaning to the g skill just because it has a heat spreader. is this a wise move is the heat spreader worth having? is g skill a good product?
Are there any specific types or specs fo the ram i am looking for
thanks
thanks
