Clearance between CPU heatsink and PSU
fortyways
banned
Is this a common issue at all, since basically the heatsink is releasing heat all over the place?
I have a Zalman 9700, which is huge, and an Antec NeoPower PSU. It doesn't have a large fan on the bottom, it has an intake at the front and an exhaust fan at the rear of the computer.
There's about 5mm - 1cm of clearance between the top of the heatsink and the bottom of the PSU. Bad? I'll take a pic if I need to.
Does the heatsink have a fan on the top? If it is then I would say it's not really a problem, but the airflow would be restricted.
Sorry, the fan is facing the RAM - it pulls air from there and pushes it to the rear exhaust:
:) phew, I guess I'm a little neurotic about computer stuff. I was thinking about getting a Zalman 9500 instead of 9700 which is built around a 92mm fan instead of 110mm, or investing in a case that puts the PSU at the bottom.
I might do the latter anyway, since those are neat, but it can wait now.
Thanks guys.
Thanks guys.
I've heard that the 9500 is EXTREMELY loud.. so just stay with the 9700.
