Will this work? Noobie NEEDS Advice!!
Bajadan236
Ok, this is what i have so far, i dont know if it will work, but if it will i would like to oarder it before the weekend is over cuz most of these iteams are on sale and have a special discount for the weekend olny. The total price is:
$1,985 (w/out shipping and w/ 2 HDD)
Dvd]
2x - SAMSUNG Black 20X
http://www.newegg.com/Product/Product.asp?item=N82E16827151153
Case
Antec Nine Hundred Black
http://www.newegg.com/Product/Product.asp?item=N82E16811129021
HDD
SAMSUNG SpinPoint T Series HD501LJ 500GB
http://www.newegg.com/Product/Product.asp?item=N82E16822152052
Video Card
MSI NX8800Ultra-T2D768E-HD-OC GeForce 8800Ultra
http://www.newegg.com/Product/Product.asp?item=N82E16814127288
PSU
Rosewill RX850-S-B ATX12V v2.2 & EPS12V v2.91 850W Power Supply 100
http://www.newegg.com/Product/Product.asp?item=N82E16817182072
Thermal Paste
Arctic Silver Ceramique Thermal Compound
http://www.newegg.com/Product/Product.asp?item=N82E16835100009
RAM
2x - CORSAIR XMS2 2GB (2 x 1GB)
http://www.newegg.com/Product/Product.asp?item=N82E16820145034
Mother Board
GIGABYTE GA-P35-DS3R
http://www.newegg.com/Product/Product.asp?item=N82E16813128050
CPU
Intel Core 2 Quad Q6600
http://www.newegg.com/Product/Product.asp?item=N82E16819115017
CPU Fan
ZALMAN CNPS 9700 NT 110mm
http://www.newegg.com/Product/Product.asp?item=N82E16835118020
OS
Microsoft Windows Vista 64-Bit Home Premium
http://www.newegg.com/Product/Product.asp?item=N82E16832116204
Cooling
APEVIA CF12SL-UBL 120mm Blue LED Case Fan
http://www.newegg.com/Product/Product.asp?item=N82E16811998121
I have a Monitor/keyboard/mouse.
Now i dont know if the CPU fan will fit on the q6600 beacause it said it would fit the the Core 2 Duo, but nothing about the quad core. Also I dont know if the CPU Fan and the Video Card will fit inside the case because i read that it was a tight fit and in some cases it did not fit into the Antec 900 Case at all.
Also, do i need 2 500GB HDD, because 1TB of HDD space is a **** load and i dont think i will even use 250GB of HDD space.
Sorry about the long post. ANY COMMENTS ARE WELCOMED, IM A NOOBIE THAT NEEDS ADVICE, PLEASE POST A COMMENT ABOUT ANYTHING!!!
Thank You
Dan
Everything looks good except the PSU from what I've heard their not a very good brand . You should take a look at the PSU recommendation thread before buying the rosewill. Personaly I'd go with a Antec , Themaltake or even a Ultra . The Antec 850 is very good . I am running the Antec 650 with no problems.
ceewe1 lists it on his list, http://www.computerforum.com/90117-ceewi1s-psu-recommendations.html
" Silverstone ST75ZF - $119.99 after $40 rebate
Ratings:+3.3V@24A, +5V@30A, +12V1@18A, +12V2@18A, +12V3@18A, +12V4@18A (Total +12V@60A), [email protected], [email protected]
Comments: An older design from Silverstone, this is nonetheless a top notch server grade unit. A top quality unit at this price, despite the relatively low efficiency."
How about this PSU:
Antec True Power Trio TP3-650 ATX12V 650W Power Supply with Three 12V Rails
I have one consern, will all the hardware work with eachother, with this set up:
Qty. Product Description Savings Total Price
SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B - OEM
Item #: N82E16827151153
Return Policy: Standard Return Policy
$61.98
($30.99 each)
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
Item #: N82E16811129021
-$10.00 Instant
$139.99
$129.99
SAMSUNG SpinPoint T Series HD501LJ 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822152052
Return Policy: Limited 30-Day Return Policy
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $29.99 2 Year Service Net Replacement Plan -- $39.99
$109.99
Hanns·G HW-191DPB Black 19" 5ms DVI Widescreen LCD Monitor - Retail
Item #: N82E16824254005
Return Policy: [LCD] Limited Non-Refundable 30-Day Return Policy
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $29.99 1 Year Service Net 1 Peripheral Extended Plan -- $39.99 2 Year Service Net Replacement Plan -- $39.99 2 Year Service Net 1 Peripheral Extended Plan -- $49.99 3 Year Service Net 1 Peripheral Extended Plan -- $59.99
-$30.00 Instant
$199.99
$169.99
MSI NX8800Ultra-T2D768E-HD-OC GeForce 8800Ultra 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
Item #: N82E16814127288
Return Policy: Limited Non-Refundable 30-Day Return Policy
Select An Optional Extended Warranty Plan 1 Year Service Net 1 Peripheral Extended Plan -- $49.99 2 Year Service Net 1 Peripheral Extended Plan -- $69.99 3 Year Service Net 1 Peripheral Extended Plan -- $99.99
$30.00 Mail-in Rebate
$594.99
Antec True Power Trio TP3-650 ATX12V 650W Power Supply with Three 12V Rails - Retail
Item #: N82E16817371001
$40.00 Mail-in Rebate
$129.99
Arctic Silver Ceramique Thermal Compound - OEM
Item #: N82E16835100009
Return Policy: Consumable Items Return Policy
$4.99
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400C4 - Retail
Item #: N82E16820145034
Return Policy: Memory (Modules, USB) Return Policy
$204.00
($102.00 each)
GIGABYTE GA-P35-DS3R LGA 775 Intel P35 ATX Intel Motherboard - Retail
Item #: N82E16813128050
$129.99
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail
Item #: N82E16819115017
Return Policy: Processors (CPUs) Return Policy
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $39.99 2 Year Service Net Replacement Plan -- $59.99
$277.99
Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD - OEM
Item #: N82E16832116204
Return Policy: Software Return Policy
$111.99
APEVIA CF12SL-UBL 120mm Blue LED Case Fan - Retail
Item #: N82E16811998121
$6.99
ZALMAN CNPS 9700 NT 110mm 2 Ball Ultra Quiet CPU Cooler - Retail
Item #: N82E16835118020
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $14.99 2 Year Service Net Replacement Plan -- $19.99
-$20.00 Instant
$79.99
$59.99
soory for the crappy copy n paste. lol, but what do you guys think about it, will it work properly?
Thanks
Dan
Everything looks fine and yes the Zalman will work. I'm not trying to talk you out of the Quad core but you do know that the new Intel Quads are coming out soon and that they will be better and run cooler than the Q6600. Just a thought before you spend your money. The Q9450 will be around $316.00 and have 12mb of cache and will be 2.66 instead of the Q6600 2.4.
I think the Q6600 is still best value for money at the moment. It is just two E6600 stuck together and that is more than enough for a majority of tasks.
Thanks for replying, when will the Q9450's price drop? And how much better is it then the q6600, soory for my lack of knowlage about CPU's. Again THANKS for replying.
Thanks
Dan
