Is there a maximum length for ethernet cables
Jon Boy
Hi, I was wondering whats the max length for an Ethernet cable before it needs a booster signal?. Reason I ask is I just "borrowed 1000ft of cheap cable from work and ran a cable from the router to my computer. Just wanted to know if what I am using is too long or well within its capabilities. I'm using about 5 m of cable I guess, its cheap and has only 1 layer of insulation if that makes any difference.
Thanks Jon
I have already cut it to around 5 m and yes I have a crimping tool. I have made the cable and am using it already. Just wanted to know whether it was too long and slowing my download speed etc etc.
As for extra length I don't need it as in comparison to a 100m cable it is very short and I do have an extra 2 ft anyway.
[-OMEGA-] said:
So you are going to cut the cable so it's only 5-7m correct?
Correct
Thanks for the help people.
Jon
I was asking because i'm sure some "noobs" may just coil up the 1000ft cable so it only takes up one foot of space, and think that will fix the problem.
That's funny, You made me laugh. :)
HAHAHAHAHAHA that made me laugh too, no I'm not that stupid lol. If I made that mistake there is no way in hell I could stick the connecting bits on the end :P.
